goducks10 wrote:
He needs to look at the door sticker that shows the payload rating. Even with the low 6700lb GVW Rams can be anywhere form 1100-1600lbs on payload. Just depends on the trim level and options added. Once we know that then better advice can be given.
Yeah, but add two adults at the very least, fill the fuel tank, add the hitch and now you've lost some of the little that you only had to begin with as far as payload goes....can't be much to begin with.
Surely the guy has an owners manual...got to be a section in there are recommended towing for the truck.... I mean, it's full of information that the owner of the truck might find valuable, .....like now:)
