epbigfoot's avatar
epbigfoot
2013 F150 Ecoboost transmission hiccup?
Hello. I read every day the forum and have gotten great response on a few of the problems I have had. I have a 2013 F150 Ecoboost, 3.31 rear end, have had no problems with small camper a 2012 Slx 185RB. Going to a friends funeral in the hills, SEMO. going approx. 55 thru hills, stays in 6th gear, sometimes dropping to 5th. But, on several occasions topping the hill, and starting over, the trans. dropped from 5th to 4th and then to 3rd. Engine revving up to 4 grand. Ford keeps telling me I have hill decent. NO I don't. Anyone have this type of problem? Truck has 23000 miles on it and is 41 months old. I am afraid I may be getting a run around from my Ford Dealer. Any help or comments would be appreciated.
  • if you have it in "tow/haul" mode, the transmission will do that on the downgrades. Each time you press the brake, it will downshift 1 gear. It'll do it on it's own too, if it thinks you are going to fast..
    I don't really like that feature, because most times, I don't need that much engine braking on the downside..
    So, I disengage T/H mode on the downside. If I need to downshift, I just do it manually.
    Good luck!
    Mitch
