Dave_H_M
Oct 15, 2015Explorer II
DirtyOil wrote:Ramp Digger wrote:
Just thinking,why not use a small electric fuel pump with an in cab toggle switch to operate it.Simply pump fuel from the aux tank thru an in line filter directly to the factory fill hose pipe.No having to stop and shut off valves or worry about check valve failure. Just turn the pump on and off from the drivers seat as you watch fuel gauge while driving. Any thoughts? Is this legal?
x2 this is what I have on my truck, works great! I do have a ball valve at the tank, the pump and filter are mounted under the bed and line is "T" into the factory "filler hose".
I think that is ok even if you are running gas and are pumping out of the dip tube on the top of the tank.
44,029 PostsLatest Activity: Jan 21, 2025
