usmcshepherd's avatar
usmcshepherd
Explorer II
May 04, 2014
2013 Lance Right Turn Signal
All....we are out on our second trip of the year and discovered just as we arrived at campsite that right turn signal isn't working...nor is the right reverse light, but running lights are good to go. We have a 2014 1172. I've checked the connection at the plug to the truck as well as cleaned them with no luck. I've found reference in owners manual about a exterior light fuse box but I can't find it. Does anyone know where this would be? I'm thinking that the 7.5 amp fuse might be out. Any other ideas or places to check would be appreciated!
  • I would check any cabinets or under the step up to the cab over. lots of electronics hidden in there in my lance 1055
  • Yeah I read that but there isn't anything there or at least in plain view! The only fuse panel I see is the main one. Unless it's buried underneath something which requires pulling stuff apart...but that doesn't make sense as you'd think it would be readily accessible!
    the manual states that it is inside on the drivers side front forward corner of the main floor
