vwsportbug
Oct 10, 2021Explorer
Hi there. Just saw your note about your roof. Good to hear that they have an aluminum frame up there. I have a 2013 Maverick 2902 so very similar camper. One issue I'm having as I prepare to winterize my camper this season (the first time I've had to do it), I can't seem to find the low point drains. I see the water heater bypass valves, the fresh water drain valve, the water pump bypass so you can pump antifreeze through the system, etc. BUT I can't locate the low point drains for the HOT/COLD water system.
There looks like one capped pipe behind the left rear wing (in the area where the sewer dump pipe is located). But there is only the one. I want to make sure I get everything drained.
Have you located them on your 2910?
