FishOnOne
May 03, 2017Nomad
ShinerBock wrote:FishOnOne wrote:
Not sure I understand your entire question, but we bought a used 05 Ram 2500 with a 2 inch lift on the front end which leveled the truck, but with a ~300 gallon tank in the bed and a 1,000 gallon tank on a custom tandom axle trailer it squats ~2.5 inches which makes the truck look like its dragging its rear. In addition the truck felt very unstable so one afternoon those spacers got yanked out. I'm not sure if this helped the handling or not at this point but it looked nice and level when loaded.
So for me adding 2 inches to the front makes the truck look nice when unloaded, but not so nice when the trucks rear end compresses with a load.
Also the Fox shocks from what I hear require to be rebuilt every 30k-40k miles so you may want to factor that in when purchasing a very $$$ part.
Although I am not to concerned about the cost of it, I will not be using it off road that often to require a re-valved every 30k-40k. Maybe around 50k-60k which is around the time I replace shocks anyways, and a re-valve is usually cheaper than full replacement.
The Thuren coil and track bar kit is little different than a spacer. Spacers generally make the truck ride rougher and do not extend the wheel travel which is counteractive to what I am trying to achieve. The Thuren kit replaces the stock stiff coils up front with softer coils that allow for greater wheel travel to soak up bumps making the vehicle more stable on rough roads. I can't get Bilstiens up front because you have to get shocks specifically valved for the coils which is why I will probably just go with 5100's in the back since I am keeping the rear coils stock.
The rear coils on this truck are pretty strong and hardly budge with added weight compared to leaf spring 3/4 tons I have had before. Empty, the back sits about 3" high. I have had over 2,100 lbs worth of deer corn and feed in the back before and it only lowered the back by about 1.5-1.75" with the front still sitting lower. From my research, the kit will lift the front about 1.25-1.5" over stock once it gets settled which will still leave the back high by about 1.5-1.75".
What I mainly tow never has made my rear squat more than this amount besides the RV which will drop it by a good 2". This is the only thing I am thinking I will need the Timbrens for and set them about an inch off the axle. I prefer not to have air bags at all. I was just wondering if anyone has had this Thuren kit on their Ram 2500 with the rear coil suspension and if they even needed a Timbren kit since the stock rear coils already do a great job of minimizing squat when loaded.
I have zero experience with Timbrens but I would think you would need more than a 1" gap off the axle.
BTW...I see bigger tires in your future.
44,070 PostsLatest Activity: Aug 05, 2026
