BLTransport
Sep 08, 2013Explorer
2013 RAM 3500 Hitch Prep
I am sure this probably been discussed but, has anyone taken out the gooseneck hitch from the factory hitch prep package and placed a B&W in the location it was removed from? After looking under a truck equipped with the factory hitch and one without, I noticed that the crossmember "appears" to be identical with the exact same bolt location holding in the factory gooseneck hitch as what would hold in the B&W set up. I also notice the the factory one only uses 4 out of the 6 possible bolt holes which seems a bit dumb. The reason I ask is that I will be purchasing a new RAM this week and the one my dealer has in stock that I want has the factory hitch prep but since I currently run a B&W with a companion I couldn't care less about the 5th wheel mounting locations in the hitch prep group but I am NOT paying $300 for a gooseneck ball or jacking with the whole "picture frame" plate just to use a different 5th wheel setup. Your thought?
Sorry so long.
Sorry so long.
