Turtle n Peeps wrote:
ScottG wrote:
Make sure your brake lights aren't on.
There was a problem with some trucks having a brake slight switch that wasn't adjusted right and it would cause the lights to come on when the driver hit some kind of bump. It was bad enough to keep knocking the CC off on the interstate.
Keep in mind the brake light switch can can only be adjusted once during installation. If done wrong it has to be replaced again.
BTW, you can put your toe under the brake pedal and hold it up to check and see if this is the problem.
Really good advice right there ^^^^^.
I just told my friend the same thing when his cruise stopped working. Lift up the brake pedal and see what happens. It worked again he just told me.
chevman
