NC_Hauler
May 19, 2013Explorer
goofy location for the Sirius radio antennae location to be sure...Other than the grille, the LED rear lights, LED signal lights, the body looks pretty much the same as the 12'. I guess if you see a 13' coming at you, you'd be able to tell by the projector head lights. from behind, it would probably be the LED tail lights.
Rick, I could be wrong, sure wouldn't be the first time, but I swear the truck seems to set "more level" than the 10 or 12 where the tail end was higher in the air..If I'd been thinking, I'd measured the 12 from the ground up..even the 10 was the same height as the 12'...I had the 17" tires on both trucks. Also have the 17" tries on this truck also.
Anyone out there able to tell us with a 10' or 12' Dodge/Ram 3500HD CC/LB/4X4, what the height is from the ground to the top of the tailgate?
Other than that, tailgate, badging pretty much the same...The cummins logo has "turbo diesel" in red letters...
love the way they do the rear fenders, smooth lines...looks good.
44,070 PostsLatest Activity: Jul 01, 2022
