1oldtruck wrote:
I went back and spoke with a salesman. The truck is a used truck. The previous owner traded it for a dually. They had a fuel tank mounted in the bed and removed it. The fuel line is still hanging out of the bed side with a bolt in it to plug it. Is it a major problem to remove the line or just avoid the truck?
Well again they are asking WAY to much money for something they bought for wholesale. Then add in it had an aux fuel tank and was not removed properly and I would not buy it unless you could get them down to around wholesale. Ask them who removed the tank, if it was them run far away from that dealership as fast as I could. A bolt stuck in a fuel line is NOT the way to do that. Remove the tee fitting with a straight barb fitting.
Don
