kaydeejay
Feb 23, 2014Explorer
jbufton wrote:That engine will run 4000 rpms all day long. Peak rpm is north of 5500, so you're not even close!
Thanks guys, now I understand that it will actually run higher RPMs with the lower gears. I think I'm going to stick with it for a bit and get used to the way the truck runs. The truck maintains speed no problem just gets a little throaty up steeper hills. At lower speeds there's no issue at all.
You have a 6-speed transmission, so just lock it into the gear where it's happiest (probably 5th), select Tow/Haul and let the computer work its magic.
It won't let the engine lug or over-rev. In fact, it's probably smarter than you or I!
