Redsky
Feb 24, 2014Explorer
You would have been far better off to locate a 2013 truck with 4.10 gears. I never buy a truck or SUV for towing without a 4.10 rear end even if it makes the search take longer and negotiations with the dealer trickier.
Where the 4.10 helps is with acceleration and when going up a steep grade. The engine will be in its peak power band at towing speeds and provide more power.
Options are to change gears, change truck, change trailer, or live with it as it is. Hopefully you will do your research next time before you buy a new tow vehicle instead of after the fact.
