06Fargo wrote:
What does the Subaru's Owners Manual say are the towing limits?
Do you want USA or the REST of the world specs. USA is about HALF of the rest of the worlds tow specs for a Subaru.
Reality is, around 3-3500 would be about max WITH Trailer brakes on anything over 750-1000 lbs would be my limit. Along with something that is very aerodynamic.
For example, not that the OP is going to be this heavy....my hp needs when I pull at 15K, at 70sq ft of frontal area is around 105HP, push that to 90 sqft, and you need 135hp, same HP as a 25K rig at 70sqft! Frontal area and aerodynamics can change these HP amount plus/minus 30%. Op will be under 10K total lbs more than likely, so not a lot of hp is needed per say. BUT< the motor will need to run in the power band where the appropriate HP is being produced.
Marty
