Hi,
What you are looking at is not really a "Max" towing capcity. Is this specs for the 3.7L gas engine? The Max tow will have the 3.5L Ecoboost, have the ability to tow 11,000 pounds (give or take) and have a much higher cargo rating.
You might be getting what is left on the lot or something.
What is probably going to happen is you will have a 5,000 pound trailer with a 600 pound hitch weight, with only 1,000 pounds left to carry cargo, passengers and such.
The "Tow Max" is rated at around 2,300 maximum cargo rating. The trailer weight rating is closer to 10,000 pounds.
Because you are buying new, why not get the higher capacity truck? THen if you decide to upgrade the trailer sometime in the next 10 years, you will not need to upgrade trucks too!
Fred.
