Veebyes wrote:
jpbuch9309 wrote:
Its not if it can pull it its if it can stop it safely
When you get into a turn a little hot & the beast behind you wants to keep going straight what would you rather be sitting in, the 150 or the 3/4T?
Once again trailer brakes stop the trailer!
If you go into a turn too "Hot" that is driver error, but the best answer is brake hard until in the turn then power through it.
This is far less likely with a 5er than a long TT, so advantage 5th wheel.
Once again may have flawed thinking about cornering, brake before apply power in the curve, the package is more balanced.
