gopherslayer's avatar
gopherslayer
2014 f150 max trailer pkg
Found a screw with this pkg and ecoboost near me with 27,000 miles. Price is $27k. XLT pkg and XTR pkg with rubber floors! :CDecent price? I've been out of the market with regards to prices and it seems decent price wise. Was a lease return from a contractor. Drives nice and really goes with 3.73 gears.
  • 3.73s in that truck are perfect for towing. With today's torque and transmissions, 4.10s etc are no longer needed. Not many "mountains" in WI.
  • eichacsj wrote:
    Could be good, pull a KBB and NADA on it. Only you can decide if you plan to tow with it, 3:73 gears are not that conducive to much towing, good mileage empty but wouldn't tow much in the hills/mountains. You will get overwhelming amount of opinions on that.
    You must have missed the part where the engine is the Ecoboost. I had a 2012 with the boosted V6 and 3:73 ratio and it is a pulling beast. I was pulling a 7,500 lb. 5th wheel and it would pull it as good as my 2016 Superduty Powerstroke pulls a 14,000 lb 5th wheel with a 3:55 ratio!
    You do know that 3.73 rears is the preferred ratio for towing don't you. and pretty much the lowest gear offered in a off the lot F150. Most come with 3.55s or higher. 3.73 also is the gear for the max tow 150. You can get a 4.10 in that year. IF you could find one. However. the tow rating for the 4.10, is higher than the 3.73 with the same engine. How do I know? I have the Ford towing guide right in front of me.
  • Finding both packages together is hard. Sort of like finding a F250 with 4.30 gears.
  • If I were in the market for a late model F150, I'd also be looking for one with the Max Payload package in addition to the basic trailer package.
  • Could be good, pull a KBB and NADA on it. Only you can decide if you plan to tow with it, 3:73 gears are not that conducive to much towing, good mileage empty but wouldn't tow much in the hills/mountains. You will get overwhelming amount of opinions on that.
