bdhoun's avatar
bdhoun
2014 F150 throttle position sensor
How many of you have had the dreaded throttle body, throttle position sensor problem? Symptons-driving down the road, the dreaded wrench pops up on the display and you have no throttle response at all. Turn off the truck and then back on and voila, you can drive again.
My 2014 has now had the throttle body replaced twice. Once after 16 months, and now again after 27 months. 1st was warranty, 2nd one not so lucky.
  • gopherslayer wrote:
    Have you tried the TPS reset procedure?
    And what procedure are you referring too?
  • donn0128 wrote:
    I have to ask, what air filter are you using? If you have an oiled filter therein could by your problem.
    ?I have it changed at my mechanic, so its not oiled.
  • Add this to the fuel pump fuse melting on 2009 - 2014 f150s. Anyone that has this model check it now before you are stranded.
  • Have an 06 Expy that needs the ETB changed out now. Found this video that explains it a little ...
    https://www.youtube.com/watch?v=FDpUo3UPmto
  • I have to ask, what air filter are you using? If you have an oiled filter therein could by your problem.
