aamyotte
Mar 23, 2014Explorer
As noted above the 80% rule of thumb is good to go by. My current trailer is fairly light but I will be upgrading in a couple of years to a larger unit. What I do is calculate 80% of the max tow capacity and use that figure for my loaded trailer weight. I know roughly how much I load the trailer for camping and add that to the dry weight and make sure that I'm under my calculated 80% weight.
Some trailers have high GCWR compared to the dry weight. If I use the trailer's GCWR it would put some units out of range for my towing capacity even though MY camping style (stuff that I bring) will never reach the trailer's GCWR.
I use the load carrying capacity of a trailer to determine if there is enough capacity for my stuff and to see if the manufacturer has built the unit to the limits of the frame and axle capacity.
