acut2660 wrote:
Now, is there anyone out there using a 2014 GM half ton as their TV. I just purchased a 2014 Keystone Bullet 272BHS. Dry weight is just under 5,000lbs. Based on the numbers on the trailer CCC will bring the allowed GVW to 6,500lbs. Going to be using Equalizer WDH w/ SC. Anyone out there have a similar setup?
My trailer as it sits now is heavier than your GVWR, and I have a noisy Equalizer, and the 2010 version of the trucks you are asking about. The new trucks are slightly more powerful so you should have to trouble with that trailer and a Sierra (or Silverado if you must go Chevy) so long as the rear end is above 3.08.
