CaptSailor
Jul 03, 2016Explorer
budwich wrote:
:-( I see you said the slides work with the battery disconnect switch switched... hmmm. There got to be more to the "story" than that.
when you say "battery disconnect switch behind it"... do you mean the fridge? If you turn off 12v to the fridge, it will not operate.
There is a battery disconnect switch attached to the trailer tongue, right behind the battery. Looks factory to me, but couldn't say for sure. I noticed it the first time we took the trailer out. Parked it, put out the slide, then realized no lights! Went looking for the problem, and found that switch. Like I say...the slide had power, but none of the lights, etc.
44,056 PostsLatest Activity: May 04, 2014
