bobndot
Jul 06, 2016Explorer III
Parked off grid, your 60 watt solar is not keeping up with the draw of the things running in your TT.
While you are not there , I would pull the fuses for , gas/propane detectors, radio/tv .
Just make sure the fridge is still in operation prior to leaving.
The detectors alone are probably pulling about 20 amps a day from your battery. At best, a 60 watt panel is pumping maybe 3-4 amps at peak for a very short time during each SUNNY day.
The fridge while running on gas is pulling at 1/2 amp per hr. or more, depending on make/model.
44,056 PostsLatest Activity: May 04, 2014
