AidenJ wrote:
Originally Northern Lite had 3 floor plans in the 10-2 series. The CD or center dinette, RD or rear dinette with the bath up front and the RR which is the one pictured. Not sure when the RD went out of the line up.
The RR was the 1st to go with dry bath.
Good info, thanks!
Noticed some of the walls in the bathroom area in the NL 10-2 pictured in the Craigslist ad (RR) were not seamless pieces of smooth fiberglass like the newer units. Appear to be a bunch of flat panels sandwiched together with plastic trim. Cirrus uses a similar, multi-seamed construction in the wet bath/shower areas of their 820/920's. IMO this type of construction is much more difficult to keep clean and more prone to leaking/separating/moving over time.
