Gr8life
Jan 18, 2014Explorer II
I owned a previous model a few years ago, a Bronco 1200. Palomino addressed any complaints I had. The older models required that the top be partially raised to open the back door. Now, I can get inside, sit upright at the dinette. In fact, for quick overnight stops, I will not even be raising the top while using the dinette bed feature. The side walls were lower which made it nearly impossible to use with the top down. The lift system was the old crank up kind instead of the new one button electric lift.
I realize that Palomino is not top of the line, but should serve my needs well. I saw a lot of used campers that originally cost 3-4 times what mine did with huge problems while shopping for mine. I prefer simple and new over old.
