pianotuna
Aug 31, 2014Nomad III
Hi Bob,
I'll do a test as I do have a kill-a-watt meter.
base load during test 0.45 amps volts 119
I operated the Nuwave with a pot with one cup of water in the bottom
On the lowest possible setting (100 f)
amps varied between 6, 3, 0.45 and back to 6
volts varied between 114, 117, 119 and back to 114
On the highest possible setting
amps 10.85
volts 110
amps 10.85
volts 110
Bob B wrote:pianotuna wrote:
Hi,
Anyone who is going to go electric may wish to consider an induction cooker. I have one from nuwave and I've not used the stove since. It allows heat control by 10 F increments. The best thing is that it heats the pan--so almost all the energy goes into cooking the food.
Nuwave
Any idea how much current draw those have when you are really cranking up the heat?
44,071 PostsLatest Activity: Aug 16, 2026
