sleepy's avatar
sleepy
2014 Project report, Stove removal... Electric mod
I went with all electric cooking: PVSolar at its best... generator back-up. I seriously doubt shore power will ever be used,
Why remove the propane stove? I boiled eggs one time in 11 years on the stove... it was the only time the stove top was ever used. The oven was on three times to try to bake Papa Murphys pizzas.
After 11 years of hauling the stove I removed it and gave it to Suds54... he picked it up a few days ago...
This is the hot plate storage area being checked out when it was under construction. I doubt that the hot plate will ever be used... it will sit neatly on top of the convection oven if needed and easily plugs into the recepticle.
It has it's own dedicated GFCI recepticle from a sub panel that has a circuit breaker. It has shore power, generator, battery, PVSolar with a new inverter.
The black area around the convection oven is a mesh to remove heat from the sides.
The oven functions extremely well... we bake or broil most of our food that isn't microwaved.
Broiled Asparagus with Garlic Parmesan cheese... Oh My Goodness... throw on some Viadalia Onions, bell pepers, tomatoes... and Chicken or Ribs... no problem
Note:
The 20" x 8" galvinized storage area is made from a 16" section of airconditioning duct and a blank end for the back.
The door came from Home Depot special order
The labor came from me in 2 hour spurts... between my nursing duties... putting drops in Janets eyes
I hope that you like it...we love it.
  • pjay9 wrote:
    What is the draw on your battery system to run the Oster? What is your battery system? I know you installed batteries under sink if I remmeber correctly. I know you have massive movable PVSolar panels. What inverter did you go with?
    Your install is clean, neat and good use of available materials i.e. DUCT.
    What he said!! :B
  • What is the draw on your battery system to run the Oster? What is your battery system? I know you installed batteries under sink if I remmeber correctly. I know you have massive movable PVSolar panels. What inverter did you go with?
  • Nice Chet! I was debating on getting one for our TC since we don't have an oven.
    Not sure how much I'd use it since we have the baby-q that we love.
