Walaby
Apr 19, 2016Explorer II
dicksenn wrote:
As far as using the axle weights would I just get an actual truck weight from a scale divide by two considering the number of axles and then use the difference between that number and the GAWR of the rear axle?
If you weigh your truck at a CAT scale, ensure each axle is on it's separate pad, and you will have actual weights on each axle. Then subtract the rear axle weight from the RGAWR to tell you the available rear axle payload.
