x96mnn
Sep 22, 2014Explorer
Really comes down to your comfort level and experience. You will get responses all over the map with some saying your way over and others who tow twice as much with no problems at all. If you bought it already, or really want it, nothing said here will change it.
Personal opinion having hauled less with the same, I don't think your going to have much fun traveling. If your not going to travel or move it only once in a while 50 miles you could live with it.
One more thing, if you relocate everything to the rear to try and make the tounge weight less you could set yourself up for a very bad experiance. Lack of tounge weight is the leading cause of sway, poorly balanced rv, your truck will not hold that trailer back if it starts to go bad. Your better off trying a WD antisway system to help balance and if your putting in airbags it will look fine.
44,072 PostsLatest Activity: Aug 30, 2026
