Copied and pasted:
Energy efficiency terminology
Energy efficiency is similar to fuel efficiency but the input is usually in units of energy such as British thermal units (BTU), megajoules (MJ), gigajoules (GJ), kilocalories (kcal), or kilowatt-hours (kW·h). The inverse of "energy efficiency" is "energy intensity", or the amount of input energy required for a unit of output such as MJ/passenger-km (of passenger transport), BTU/ton-mile (of freight transport, for long/short/metric tons), GJ/t (for steel production), BTU/(kW·h) (for electricity generation), or litres/100 km (of vehicle travel). Litres per 100 km is also a measure of "energy intensity" where the input is measured by the amount of fuel and the output is measured by the distance travelled. For example: Fuel economy in automobiles.
Given a heat value of a fuel, it would be trivial to convert from fuel units (such as litres of gasoline) to energy units (such as MJ) and conversely. But there are two problems with comparisons made using energy units:
There are two different heat values for any hydrogen-containing fuel which can differ by several percent (see below).
When comparing transportation energy costs, it must be remembered that a kilowatt hour of electric energy may require an amount of fuel with heating value of 2 or 3 kilowatt hours to produce it.
Energy content of fuel
The specific energy content of a fuel is the heat energy obtained when a certain quantity is burned (such as a gallon, litre, kilogram). It is sometimes called the heat of combustion. There exists two different values of specific heat energy for the same batch of fuel. One is the high (or gross) heat of combustion and the other is the low (or net) heat of combustion. The high value is obtained when, after the combustion, the water in the exhaust is in liquid form. For the low value, the exhaust has all the water in vapor form (steam). Since water vapor gives up heat energy when it changes from vapor to liquid, the liquid water value is larger since it includes the latent heat of vaporization of water. The difference between the high and low values is significant, about 8 or 9%. This accounts for most of the apparent discrepancy in the heat value of gasoline. In the U.S. (and the table below) the high heat values have traditionally been used, but in many other countries, the low heat values are commonly used.
nuff said!
