Sifter
Oct 06, 2014Explorer
brulaz wrote:
EDIT: the 240RKS has a very high tongue weight, ours is 1130#. Don't know about the 25Y. And the loaded 240RKS (7500-8000#) definitely maxes out our EcoB F150. Depending upon tongue weight, the loaded 25Y would probably be too much. I suspect you will need a heavier duty truck than the Tundra to tow the 25Y.
Thats a very heavy tongue weight on yours, what did you add?
25Y
Dry Axle Weight (approx. Lbs.): 6093
Dry Hitch Weight (approx. Lbs.): 760
Net Carrying Capacity: 3147
Gross Dry Weight - Lbs.: 6853
Gross Vehicle Weight (GVWR) - Lbs.: 10000
Exterior Length (approx. w / hitch): 30'0"
Exterior Height (approx.): 10'11"
Exterior Width (approx.): 8'6"
240RKS
Full Feature Dry Weight - Lbs.6250
Exterior Length (approx. w / hitch)28'8"
Dry Hitch Weight (approx. Lbs.)775
Net Carrying Capacity 1850
Maximum Trailer Weight - Lbs.8100
Dry Axle Weight (approx. Lbs.)5475
Exterior Height 11'4" w/AC
Interior Height 6'11"
