DWeikert
Sep 20, 2015Explorer II
Least expensive and probably the best way to improve the unloaded ride is to lower the air pressure in your tires.
Based on this inflation chart-
Michelin Inflation Chart
Unloaded your rear axle is probably under 3000 lbs so depending on your actual tire size 50 psi in the rear would still be well within the weight rating and would soften the ride.
The down side is the TPMS will probably nag you about the low tire pressure.
44,071 PostsLatest Activity: Aug 16, 2026
