Mike_Up's avatar
Mike_Up
2015 Explorer
We just bought a 2015 Explorer Base 4WD model for my wife with Ford Sync/Sirius Radio and Tow Package.
This Crossover (they call it an SUV :D ) could be a nice tow vehicle for lighter and shorter campers.
While with a max 500 lbs hitch weight limit, it'll be limited to small travel trailer with around a Max "LOADED" weight of 3900 lbs, to stay within the hitch rating.
While the drive train looks to be less powerful, it is surprisingly powerful. I had a 2005 Pathfinder 4WD (true locked 4 Hi with truck frame) and the 4.0L that was rated for higher torque than the Ford 3.5L. The Nissan Pathfinder felt less powerful down low despite weighing the same.
The reason is gearing. The Explorer has some pretty high ratio gearing along with a 3.65 axle ratio in the 4WD model.
It gets up and goes with that gearing even though the rated torque is 255 lbs at 4000 rpms.
Now here's the most surprising benefit. It has 1398 lbs of payload right on the yellow tire loading tread act sticker on the door jam. That's only 30 lbs less than my previous 2010 F150 Crew Cab 4WD 5.4L 3V truck! It's also higher than many 1/2 ton trucks.
So you can probably load it up with a family, get a small TT or Hybrid, and do pretty good with it.
Really surprised as it has more payload than my late 2008 Ford Explorer Sport Trac by over 100 lbs.
Hek, it even has Trailer Sway control and a Tow mode.
Granted it's crossover design limits hitch weight but within that, it could be a pretty decent tow vehicle.
  • I towed my 4500lb 1992 Jayco with our 2011 Explorer XLT twice when we were in a pinch. It did the job admirably but I wouldn't have been happy if the trailer was taller like some of the newer ones are today. I would tow one of the new larger popups in a heartbeat with it though.
  • There are plenty of brake upgrades available for the Explorer now that it is sold as a Police Vehicle. Ours have been pretty durable.
  • Side note - U-Haul will still not rent you a trailer if the TV is an Explorer.
  • I traded my 2002 Explorer 4x4 V8 Limited in for a 2012 4x4 Limited, both fully loaded including factory tow packages. I can say for a FACT these two vehicles are in no way shape or form even remotely related to each other, period. The 2002 is a truck, the 2012 to present is a Flex. When I bought mine (unchanged to date), there were more Bently's on the road in this area for at least the 1st year, people thought it was a Land Rover.
    Never had a problem towing the boat in either, but there sure is a difference in power. The V8 feels way more secure power-wise where the 2012 makes up for it with 6 speeds fancy shifting routines and assisted power train braking.
  • kknowlton wrote:
    I hope it works out that way. We had the older Explorers and found the weak spot was brakes. Had to have those (and tranny) serviced more often than normal when we were towing - and we usually towed just popups. I wonder if the brakes have been redesigned, since the entire car has been.
    I had great luck with my 2008 Explorer Sport Trac, never any brake troubles. Even towing this. That Sport Trac though had a 730 lbs hitch rating thanks to it's truck frame.
  • I hope it works out that way. We had the older Explorers and found the weak spot was brakes. Had to have those (and tranny) serviced more often than normal when we were towing - and we usually towed just popups. I wonder if the brakes have been redesigned, since the entire car has been.
