Tom___Marie's avatar
Tom___Marie
2015 Renegade Explorer Cummins 350 9L
Just returned from a 5K mile trip out west and had two engine repair incidents . Engine was operating normally pulling a 6degree incline when an engine amber light ( not the check engine) came on .Contacted Cummins help line advised them of the code displayed and was advised to proceed to the nearest Freightliner Cummins dealer in Calvert City,Ky as the code was a failure of the ECM to communicate with the Regeneration system .Three + hours of diagnostic time and the replacement of an $ .80 fuse in the ECM resulted in a $260 bill even though the engine is under warranty with 19k miles.
800 miles later got another amber light not the check engine.Cummins advised again to proceed to Freightliner Cummins in Laramie,Wy.Their computer found no faults because they did not have the necessary Cummins Insite computer. After being required to pay them $105 for five minutes work they directed us 50 miles back to Cheyenne,Wy to Floyds Freightliner Cummins dealer. After many hours of diagnostic time and necessary removal of engine parts to determine the problem the EGR cooler and EGR valve were replaced .These parts were almost completely packed with carbon deposits with no explanation as to the causeother than failure of the EGR. The good news is that this repair over a period of four days was covered by the Cummins Warranty. The actual cost of the repair is unknown. The engine performed flawlessly for the remaining 2,500 miles.
Please be aware that you must determine from the Freightliner location referred to that that they are a dealer with complete Cummins Service with the Cummins Insite computer . Apparently there are many repair shops indicating Cummins Service but do not have the necessary computer equipment to properly diagnose an engine problem. It should be noted that the "Check Engine " never illuminated only the amber engine light but Cummins advised the condition could have led to check engine then derate and stop.Beware of the TA Truck stops service indicating Cummins Service.
1 Reply
  • You should not have been charged. That is all covered by Cummins with the 5 yr government required (because you'll need it) emission warranty.
    Mine was 1st in for DEF nozzle clog, then EGR, then ?, then complete ECM, then EGR issues again, then 2 times for complete new wire harness. All that in 20K miles and about 5K with check engine on. After the 1st ECM update I lost 1 MPG and noticeable power. But per numerous checks they said everything was OK.
    These new emission motors are junk. I was heading toward removal of all the emissions junk but that is expensive also. Sold it before the warranty ran out. 2012 Cummins 350 8.2L.
    Good luck.
