Bedlam
Nov 13, 2014Moderator
My F250 with camper package only needed the upper and lower StableLoads to carry the camper. With the camper off the truck, the lower StableLoads can be disabled and the upper ones will not touch the overload springs. They will not need air bags unless they plan to tow something with a heavy tongue weight.
The crew cab length most likely will not transfer any of the camper weight to the front axle, so get a good idea of how much weight is on the rear axle to make sure you have sufficient capacity tires. I was typically around 7000 lbs on the rear without the trailer.
44,059 PostsLatest Activity: Mar 18, 2026
