Cummins12V98 wrote:
bighog01 wrote:
Educate me on these additives being added to the Ford diesels. I don't recall GM requiring these and never had to add any to the Cummins.
They seem to need a little EXTRA attention like special oil.:B
If your cummins starts consuming oil because of carbon buildup from the EGR and causing ring jacking... Valvoline got you covered with some ~$80/gallon oil.
OP,
The 6.7 Power Stroke does not require oil additives. Just simply follow the Oil Change Minder and when it tells you its time to change the oil, then you can experience a very easy and enjoyable oil change process and not have to remove intakes or deal with working around that tiny hole in the fender just to remove a simple oil filter.
