DatacomGuy
May 31, 2015Explorer
Terryallan wrote:DatacomGuy wrote:
Haven't towed yet.. but i'm assuming i'll have a little bit of droop in the rear once i hook up.
I can't find any helping products out there - Air Lift, helper springs, etc. Curious if any of you have seen anything?
I've emailed AirLift to get their input and to see if any of the F150 products might work. Will report back..
Little to no information to go on. However. IF you use a WDH the rear drop would be nominal, and IF your trailer is more than 5000lb, and has more than 500lb of tongue weight. And it apperars the TT in your sig will weigh more. You will have to use a WDH anyway. so air bags will not be needed.
Properly setup. the WDH will return the lost weight, and control to the front axle, and "lift" the rear. Air bags will not return any lost weight to the front axle, and no steering control either.
You make good points. I have the equalizer.. but still had a lot of drag in my Ram, with the soft coils in the back. I have a feeling the Expy would be the same way.
I may need to find someone to help me reconfig my WDH anyway. I really struggled with the original setup the first time around. Never could get it right and ended up having a local RV shop fix it for the low price of $140. Grr.
44,071 PostsLatest Activity: Aug 16, 2026
