Puttin
Sep 10, 2015Explorer
jasonlisan wrote:DatacomGuy wrote:Puttin wrote:
The owner's manual talks about it but it isn't mentioned on the sticker. The only thing is- it comes with the HD towing package only and for 2014 it is a mechanical system vs air in past years. Max load is 920# (WD) and 600# weight bearing). Leveling works with both applications.
Hmm, now you have me really curious. Do you have to select anything or turn anything on? How do you engage yours on your 2014?
Your window sticker should of had a line item "Continuous Control Suspension" on it.
You don't turn anything on, the computer senses load and spring height, then auto adjusts.
