Earthroamer82's avatar
Apr 21, 2015
2015 Ford Transit
Family is growing! Anyone towed with the new Ford Transit Wagon (12 passenger) yet?
Camper weighs in on the scales at 3950lbs, fully loaded. While the Transit with 3.5L EcoBoost and 3.31 Limited Slip Axle can tow 5000lbs.
Let me know your thoughts please!
-EarthRoamer sends
  • It should be a piece of cake with the turbo. I wouldn't worry about changing out the rear end. Yes, a lower rear ratio will make your RPM spread between shifts a little closer together, and if you had a bigger, heavier TT it could matter. With your TT you might run the transmission 1 gear lower at times to compensate, no big deal.
  • We will be towing our 2015 Coachman Clipper 17BH.... But not that fast :E
    -EarthRoamer sends
  • Based on the high roof passenger one that blew by me at 80+ MPH on I-65 a week and a half ago I don't see how you would have any problems towing a pop up behind one at a reasonable speed.
  • We will be getting the Transit 350 Wagon, low roof and regular length. Have you analyzed your MPG yet, during regular commutes and then when towing? Wondering about how much of a decrease to expect!
    -EarthRoamer sends
  • I have the Transit cargo van, long W/B, medium height roof in my sig. I will be taking my first trip this year in a few days time.
    I've only towed the Lance a short distance..to set up the hitch....and seems to be on a par, power wise, to my previous E350, V10.
    I love the van, very comfortable, lots of power, and steers so much better than the old twin I-beam drifto-matic E350.
  • Hi,
    I have a blue Transit T-250 cargo van on order, and am getting excited about buying it! Production date should be May 18th! Mine will have a 3,000 pound cargo rating, and the Ecoboost will have a 11,200 GCVWR for both 3.31 or 3.73 rear axles in the window van.
    The lighter the van, then the more it can tow, so 5,000 pound tow rating is for the lighter T-150, while the heavier T-250 can tow about 400 pounds less due to higher curb weight. The cargo van with it's slightly higher 12,600 pound GCVWR can tow 7,000 pounds in the T-150/250 with medium roof and 3.73 rear axle.
    Yet the maximum towing 'ability' is for the empty van, with only a 154 pound driver. Add more weight, and the ability is still only a total of 11,200 pounds! So a curb weight empty of 6,200 pounds (window van with 1 driver and no accessories) then you add the rest of the family, you might have a curb weight of 7,000pounds, leaving you a tow ability of around 4,200 pounds.
    I have no idea why Ford rated the cargo van for 1,400 pounds more weight rating than the window van. I guess it has to do with more weight on the empty van's rear axle?
    I am ordering a cargo van with dual A/C, windows all around, and other options, so it will look like a window van from the outside, but be a cargo van inside. My curb weight will go up by 600 pounds when the wheelchair lift is installed. I am getting a aftermarket hitch from ETrailer.com that is rated at 8,000 pounds with a 800 pound deadweight rating.
    Good luck with your van, I hope that you enjoy it!
    Fred.
  • Just looked at the specs. I recommend the 3.73 axle. 5000 pounds max tow rating will be with a 150 pound driver. So 1250 pounds of people and stuff inside (plenty of payload) will get you at max GCWR of the Transit with 3.31 axle.
    Power should not be a problem for that van.
