RoyJ
Aug 22, 2014Explorer
N-Trouble wrote:
And 10 even better than that... Then 12....
It starts to become a matter of diminishing returns at some point. Personally I wouldn't want a tranny that's always hunting between gears as that is what an 8-speed is going to do. 6-speeds seem more than enough to me but what do I know
While I agree that there should be a ceiling for optimal number of gears, you've got it backwards when it comes "hunting".
A transmission hunts when there are too FEW ratios. Imagine a 2 speed Powerglide - if you tow with it, it'll always be shifting from 1st to 2nd and back to 1st on hills, because you're rarely in the sweet-spot of either gear (only 2 sweet spots).
With an 8 speed, there are 8 sweet spots. It may shift more, but as an owner, I can tell you it NEVER hunts. It'll shift until you're in the perfect gear, at the perfect throttle position, then hold it until conditions change (hill is over, etc).
44,056 PostsLatest Activity: May 04, 2014
