ViaSteve2015
Jan 29, 2015Explorer II
PAThwacker wrote:
The 28bhs is a light weight stick and tin. 5200lb dry. 7500 gvw.
Yeah...you should be OK if you start at 5200 lbs. and add even 1500 lbs. for gear (which may be on the high end), you still only come up to 6,700 lbs. And, I did notice that you have the 2500 Suburban.
Do check to see if the 5200 includes all the options you're getting. I can't see where any options would make a big difference, but worth checking.
