ThreeEs_and_One's avatar
Nov 04, 2014
Winter Camping in Jayflight 32BHDS w/ Thermal Package
How many of you have risked using the TT during cold weather (at or slightly below freezing for lows)?
I bought mine with the "thermal package" which for Jayco means duct work to blow heated air into the underbelly, foil insulation and upgraded insulation through the TT. I know that I’ll likely have to use our water tank as a city connection could freeze and also take care of the sewer hose since it could freeze with liquids in it as well. I also plan on devising some sort of skirt (was thinking canvas with some fishing weights spaced at bottom to keep from wind blowing underneath).
I'd like to be able to use it to take the kids up to the nearby ski slopes for tubing and other winter fun.
The only thing I’m not looking forward to is having to re-winterize it after use in the winter since it will be parked with no heat.
