Tequila
May 13, 2014Explorer
I looked seriously at this model and a few other Lances, and was a little concerned about quality, plus the fact they supposidly use the Lippert chassis which has had issues (Not 100% sure on that one). I noticed a lot small things wrong, like gaps in the shower pan and things like that. I picked up a Northwood 234RBS for a few more dollars and felt the quality was far better. The only thing i did not like was the fact they are higher than the lance. And heavier. If I had the same truck you appear to have, I probably would have gone for the lance. Underside clearance is also important to me because of where I go.
What I bought is a very similar floor plan, although it looks like you may be able to squeeze past a closed slide inthe Lance, which I cannot. In mine the kitchen counterspace is larger which I think may have been the compromise there.
There is no perfect RV. You should join the LOA.
