Turtle n Peeps wrote:
mayo30 wrote:
Question.Isn't there a lot more stress and and wear on a 6 cylinder motor putting out the same power as an 8 cylinder motor?I know my 6 cylinder cummins were a lot beefier then the 8 cylinder diesels but that was years ago.
A very long answer short; yes.
When you put a big 8 cylinders worth of air through a 6 cylinder engine the rings are going to load harder against the cylinders and the cylinder pressures are going to go sky high. (comparative speaking)
The reason the Cummins parts were bigger is because they had to be. They are putting the same amount of power through 6 pistons as other manufactures are putting through 8. So things like rods and wrist pins and things like that have to be built bigger and stronger to hold the power put through them. Think how big and strong the rod would have to be if you put 350 HP and 800 ft/lbs through a 1 cylinder Cummins!! :E
Ford performed a tear down from a abused engine in front of a live audience and actually measured some of the parts that illustrated that were still in factory specifications. Again I would have no concern of the engines internals holding up to boosted cylinder pressures.
Link
You may think a 13% leak down is acceptable; I don't and don't know of any engine builder alive that thinks that's Ok.
LOL at Fords "factory specifications."
I still remember GM's "factory specifications" for BBC oil use. 1 qt for 600 miles was ok with them! :E
13% cylinder leak down must be just like the GM oil use deal and be within "factory specifications"! LOL :R
I don't know about the leak down test but the bottom line is it still made the same HP and Torque as it did brand new. :W
Perhaps GM should grow some ballz and perform a identical test with their V8 engine and dissect it for the world to see. :B- Turtle_n_PeepsExplorer
Link
13% cylinder leak down must be just like the GM oil use deal and be within "factory specifications"! LOL :R Turtle n Peeps wrote:
Link- Turtle_n_PeepsExplorer
The reason the Cummins parts were bigger is because they had to be. They are putting the same amount of power through 6 pistons as other manufactures are putting through 8. So things like rods and wrist pins and things like that have to be built bigger and stronger to hold the power put through them. Think how big and strong the rod would have to be if you put 350 HP and 800 ft/lbs through a 1 cylinder Cummins!! :E - AH64IDExplorer
We'retheRussos wrote:
Home Skillet wrote:
You use premium fuel for max horsepower.
With the lower octane fuel, the power is reduced.
Incorrect. The Octane level determines the amount of pressure the fuel can withstand before it detonates. Higher performance / turbo charged engines like the EcoBoost have high compression ratios and therefore require a high octane fuel to prevent knocking. Using a low octane fuel can cause knocking and possibly damage to the engine.
On engines that require 87, they have lower compression ratios and therefore its not beneficial to put in a higher Octane. People read "Premium" and go for the marketing when it does absolutely nothing - if anything there are tests that show your MPG will go down slightly by using a higher octane fuel than recommended because your engine is not able to ignite the fuel at the opportune time.
Russia, while that information is not correct it is no neccarrially true anymore. My wife's 2003 4Runner makes more power on premium, but can run both. That is directly from Toyota. In testing it's not worth the cost of premium, unless we are towing. Since we have the truck in my sig the Runner is rarely used for towing.
Lincoln/Ford says the exact same thing about the ecoboost in the Navigator. Premium is required to make the advertised power, but the engine runs fine on regular and regular is acceptable as the main fuel. - N-TroubleExplorerActually Skillet is correct. Just about every motor built in the last 10-15 years have built in knock sensors that will back off timing if they sense knocking/detonation occurring. I believe that is what Skillet was eluding to.
Ford site says that regular fuel (87) is required, not to use E85, and to use 91 octane or higher for increased performance - We_retheRussosExplorer
On engines that require 87, they have lower compression ratios and therefore its not beneficial to put in a higher Octane. People read "Premium" and go for the marketing when it does absolutely nothing - if anything there are tests that show your MPG will go down slightly by using a higher octane fuel than recommended because your engine is not able to ignite the fuel at the opportune time. - TystevensExplorer
Well, this is a 6 cyl designed to be run as a twin turbo. So, much like the Cummins, it has been engineered to deal with the stress by all accounts. - TystevensExplorer
N-Trouble wrote:
ib516 wrote:
You know what I couldn't help but notice was that both the EcoBoost in the Lincoln and the 6.2L V8 in the huge Yukon XL were both rated at 16 mpg combined. What happened to the "Eco" part?
"Eco" is just Ford marketing smoke and mirrors.
I don't know ... I own both a GM 5.3 V8 and an Ecoboost in similarly sized trucks. The EB gets about 10% better mpg than the V8 does in most situations, with me in the driver's seat, at least. And the EB has noticeably more power, and tows the pants off the 5.3. I'm happy enough with the "Eco" part, but thrilled when using the "boost!"
Anyway, I don't know that weighing fuel economy when charging up a hill at full throttle is the best measure!
I will say that the 6.2 seems to be a better competitor against the EB than GM's 5.3 is, and has put a new Suburban back in the running for our next family vehicle. I really don't want another 5.3, though. - It should be noted that the two engines were not rated at the same horsepower, IIRC the 6.2 has 420 and the Eco has 380. It seems as though they were pretty evenly matched although the 6.2 with the 8 speed seemed to be constantly shifting. That would make me crazy.
44,055 PostsLatest Activity: Dec 23, 2025
