N-Trouble wrote:
ScottG wrote:
Just anote, if a programmer is used then the oil-life meter is meaningless.
Explain...
It's because most programmers advance the timing* (to what it was years ago) and this causes a heavier soot load for the oil because the air fuel mixture is in the combustion chamber longer prior to ignition.
A programmer also puts more fuel in which also causes more oil degradation.
The oil life meter can't accurately take these factors into account because it changes what the ECM knows as a set value.
*Another side effect of advancing the timing is that it limits your max safe EGT because the heat is in the cyl longer. So if you had a max safe temp of 1500 degrees then it may only be safe to 1200~1300 degrees with advanced timing.
