ESDA's avatar
ESDA
2015 Silverado 2500 Hitch
I just purchased a 2015 Silverado 2500. It came with a Class 5 hitch that has holes for the safety chains on the sides and front. They way the holes are set up, I cannot get the safety chain hooks in. I have a TT that is approx. 9,500 lbs loaded. Does anyone have any ideas? This new design is really weird.
  • That shackle has a 2000lb working load limit. Personally, I wouldn't use it for a 9500 pound trailer. I'd at least try to match the strength of your safety chains. If they're gold/yellowish, they might be G70 transport chains...3/8" = 6600lb WLL. It should be marked every 1-3'.
  • US Cargo Control
    I have your same truck. Order the 3/8" Galvanized Steel shackle. $1.59 each. Get them on Amazon for much cheaper shipping (same vendor). Part No. is SPAS38.
  • Huntindog wrote:
    If you have what I do, it can be done. Gotta come in from the side and hook it towards the center of the truck. At first it seems impossible. A little practice, and it's easy.
    I think I have tried that, the hook from the safety chains won't quite make it through to be able to close. I tried a quick coupler and shackle from Home Depot but they don't sell anything large enough to be able to make it through both holes. Maybe, I'll try looking at tractor supply.
  • If you have what I do, it can be done. Gotta come in from the side and hook it towards the center of the truck. At first it seems impossible. A little practice, and it's easy.
  • Yep, just use a properly load-rated shackle or quick-link. You can buy the, at places like Tractor Supply or order from McMaster-Carr.
  • I added a couple of these with the hook facing under the car (back of the hitch). It works for my 16ft flatbed trailer.
    Hooks
