kaydeejay
Jun 22, 2014Explorer
car2900 wrote:It's not the hook up in the truck that could be the issue, it's the goose-neck adapter on the trailer.kaydeejay wrote:No, I don't have a goose neck but the B&W Companion connects to a goose neck ball post.
Do you have a goose-neck on the fiver already?
If not I would check with the Manufacturer to make sure you don't void the frame warranty if you add an adapter.
A fiver/goose-neck conversion (aka ball post) puts a lot of torque on the front of the fiver frame that it may or may not be designed for.
You REALLY need to check with your trailer manufacturer to make sure it is OK, otherwise you may over-stress and crack the frame, which will be expensive to fix and would not be covered under warranty.
