camp-n-family
Mar 18, 2016Explorer
The Sequoia is a perfectly fine tow vehicle. Just like any other, as long as it is kept within its ratings. As with 1/2 ton based vehicles, you will be payload limited. I would aim to keep the loaded tt weight under 6k as long as you can handle the tongue weight. A hundred pounds over payload won't kill it. More important is to keep it under the axle and tire ratings.
The 5.7l with the 6speed is a bulletproof combo and will pull its rated weights in the mountains without problem. It will drop a few gears but don't be afraid to let it rev, won't hurt anything. It's best power is found above 3500rpm.
