ivbinconned's avatar
ivbinconned
Explorer II
Aug 10, 2020
2016, 3500 Ram long box. Replace drive shaft with one piece?
Under load considerable shudder. I think steady bearing going. Steady Chirping sound comes and goes with throttle.
Any body switched to a one piece?
  • That’s a better looking bearing than stock.
    I had to decide so an hour ago I gave the go ahead with a single shaft build.
    Built by a driveline shop that says they have built a good number of them and had no problems. They guarantee their work.
    Heavy walled tube.
    Searching the Internet I find many proponents and many negative about this.
    I’ll let you know how this works out.
  • You’ll love it.
    How many miles? That’s a pretty new truck.
  • How do you lube the slip joint behind the center bearing when it's covered with a rubber seal?
  • IMO, sounds like a U-joint if at Hiway speed. Had a '91 GMC 2500 ext cab, LB, 4x4, 454 and it had a shudder upon take off. Ended up that GM re-located the driveshafts so angle of things was better. Cured the shudder. Don't recall now the driveshaft configuration......sorry.
  • Learned today that now Ram has factory aluminum driveshafts. Friend has a 2020 with one.
    Will install mine tonight.
