- ivbinconnedExplorer IIVehicular speed.
- Johno02Explorercomes and goes with throttle??? vehicle speed or engine speed???
- Cummins12V98Explorer IIIIs this taking off on a turn????
- bobsallyhExplorer IIhttps://www.dieseltruckresource.com/forums/
https://www.turbodieselregister.com/forums/
Go to these forums and search. Plenty of info on what you are asking. - Ram4SamExplorerHow many miles on the gear oil...? Could be the rear end..... I had a slight shudder, carrier was fine, changed the gear oil, nice and quiet.
Sam - JRscoobyExplorer IIIf carrier is bad, replace the bearing. If you go with 1-piece, you will need heavier tube. More flex in u-joint will shorten life.
- eHoeflerExplorer IICheck your U-Joints
- Grit_dogNavigator IIIt’s a pretty common mod, or used to be. I didn’t know they still were using some 2 piece shafts.
I did it on our 07 years ago. I didn’t have any extreme issues but being a stick shift, it tightened up the drivetrain considerably.
Worth it IMO
44,045 PostsLatest Activity: Aug 01, 2025
Related Content
- Jan 27, 2025Community Alumni
