Cruiseomatic
Aug 05, 2016Explorer
Replacing entire subfloor one piece at a time.
'06 Cavalier. Starting total remodel/rebuild. Starting from the bottom up and thinking about the sub-floor. It has some patches but in 2 places. Factory floor is particle board and the dealer replaced the rot with OSB that has swollen in couple places. I was thinking of replacing it all with 4X8 sheets of 5/8" or 3/4" marine grade plywood one sheet at a time so not to disturb the wall framing. Once cut, knocking the old sub-floor out shouldn't be that hard. Should only take 7 or 8 sheets. I also am replacing the undercarriage sheeting with "plastic cardboard" and thinking of sistering 2X4s on both sides of the factory floor studs with either 1/2" bolts with washers through them at set intervals or screwing them together to mount the plastic board and add strength. This is about a month or two in the future but it has been bugging me and I can't find much online about it. Not too worried about cost as I am doing it right the first time to last a long time. Once this trailer is done, It will basically be a park model. I do know that pulling the sub-floor will be a pain but it will be worth it. Thanks.
