AnEv942
Apr 02, 2018Nomad
Typical issue, getting from sink side thru front bulkhead to cabover.
Had to look, Ive done this 3 times, most recently need to run wires up to new levels monitor. First time was hard-wiring our inverter. Painful an understatement but doable. Drilling from under sink up at angle into cabinet in cabover.
However our campers lower cabinets don't wrap around the front as much. Looking at this
Have to ask if the monitor panel pulled, can fish wire be pushed down?
Suppose that would be too easy...but then you could go straight thru wall behind monitor and up thru cabinets.
Other thought is on the solar wires. As they are not connected, is there any freetravel/slack (without pulling thru) enough to attach string?
I'd also put inverter under counter closer to battery, if for no other reason only pulling smaller output wires.
But ya when I installed our inverter I thought it was going to be a simple afternoon project, into day 3 before buttoned up.
44,056 PostsLatest Activity: May 04, 2014
